O11D-1 Vertical Mount (pcie4?)
20 Jun 2012
Hi,
I have an O11 Dynamic. (not xl or mini)
I have a 6800xt liquid cooled from asus and the pipes get pushed against the tempered glass.
So I want to do a vertical mount.
It looks like i need this for pice4: https://lian-li.com/product/o11d-1-vertical-gpu-bracket-kit-pci-e-4-0/?cn-reloaded=1
But the OCUK version says pcie3 only: https://www.overclockers.co.uk/lian-li-o11d-1-pci-express-riser-cable-black-cm-016-ll.html
Any idea if this is actually the same one or do OCUK not stock the pcie4 version.
Cheers.
They do a pcie 4 version for the O11 mini but no updated version for the dynamic afaik.
I used the bracket and got a 10cm pcie 4 riser cable from elsewhere. Linkup or something like that. Works fine with my Asus tuf 6800 and Asus x570 mobo.
You could just use the pcie3 riser cable it comes with but imo it is too long and annoying.
