o2 broadband and linksys router??
7 Nov 2007
Sandwich, Kent
Hi guys
Hope you can help, my o2 BB went live today, im on the home access package (adsl) as im out of LLU coverage, and for the life of me i cant get my linksys wag54gs to connect?? the crappy live box they sent me works fine, I tried calling their customer service but was told "sorry, we dont support 3rd party routers" Do any of you clever people know what im doing wrong? I've had a look on google but cant find anything relating to adsl, only adsl2+. and those settings dont work.
Thanks in advance
thanks for the quick reply, but those are the settings i tried, but it still wont connect, i get a green light for adsl but a red light on internet and it refuses to connect the dsl connection
I had this problem with a Linksys WAG200G and couldn't get it working... after doing some research I learned that Linksys routers based on that chipset are terrible for ADSL2+ lines... with many dropped connections, and connection/speed issues in general.
I now have the O2's own router in and it's been a rock solid stable 3.8MB for 10 days without a single disconnection on my crummy line. The Linksys is getting sold!
Really i didnt think linksys were that bad for adsl2 mine wag54gs has been fine......
I didn't think they were either, but lots of problems have been reported on discussion boards. Shame, as mine was bullet-proof on standard ADSL.
the thing is im not on adsl2+ as im not in their LLU coverage, so im on the access system thats piggybacking bt wholesale, i think thats where the problem is as all the settings i find are for adsl2+. I can use the o2 box, but on most websites i have to refresh the page 5-10 times before it will be displayed?? thats why i wanted to try my trusty linksys.
Ive had the odd drop out but nothing major i have asked on the BE* forum for people to recommend a better router with a more compatable chip-set other than the BE* box as it over heats im told :)
Sent you and e mail in your trust Richdog.............................
The settings should be the same as for any other BTw ISP, i.e. VPI/VCI 0,38. What you'll need is the username and password that O2 have set.
hmmm, i tried that but it still wouldnt connect, someone told me that i need to leave the username and password blank, but the router wont save the settings without a username entered??
That's the case of O2's LLU, but you can't have a blank username on BT Wholesale - they need the realm to identify your ISP.
Finally got it sorted :) after 2 hours on the phone to o2 they gave me the settings i needed and its all working! Thanks for all your help and suggestions.
