o2 Joggler
1 Dec 2003
Liverpool
Hey,
Does any of you guys know if the o2 joggler is still available to purchase in-store as i cannot find it on the o2 online shop.
It looks likea great addition to any gadget lovers home and i want it for the kitchen.
So o2 do not sell them at all anymore?
If i pay that little extra from a third party, would i still be able to use it?
haven't they been EOL'd? i remember O2 were selling them at 50% off and i assumed that they were trying to dispose of them...
They are actually awesome, you can pay over £50 for a 7" digital picture frame and with this you can install unbuntu and basically use it as a mini tablet for in my case the kitchen.
It will allow me to stream media, watch iPlayer, have a calendar, web browser, radio, photo frame and more!
I have found it online for £65 and if that is the best i can get, i will get it :-)
I actually have a spare, I bought 2 when they were at £50 and never got around to using the second. Could stick it on MM if there'd be some interest?
:( i don't have access to MM due to a problem i had in the past, my fault as i was a lazy sender!
How much would you be looking for? Alternatively email chrisreilly @gmail.com
I picked one up whe they were £50 in store. Got ubuntu running on it (bootable usb stick). I like it. £50 for a good picture frame is a bargain without all the extra bits ;).
There's always plenty on ebay, but they are not perfect. The main problem is the heat buildup, these things have PLASTIC heatsinks and a thermal pad that makes contact with the metal stand to draw heat also.
After 30 minutes of intensive use (iplayer) it will hit 71 degrees and throttle down to 800mhz, which makes it almost unusable. TVCatchup doesn't run smooth enough, even in low quality. Still get occasional crashes/hangs/google chrome using 100% CPU/ubuntu maximus bugs and have to ssh in and kill stuff.
The touchscreen isn't very sensitive near the edge of the screen, and you just can't customise ubuntu enough to make it really easy to use on such a small screen.
In saying that, it's still very good, this thing has gigabit ethernet, 802.11n wifi, 512RAM, stereo speakers.
For £50-£70 they are very good, the only extra you need to buy is a 4GB flash stick and use synergy/vnc to remotely control it. Some people have bought usb hubs to add bluetooth/keyboards/hard drives etc.
I think the 2 main reasons for the abundance on ebay is 1. the price (£50) and 2. people buy them and realise they have no use for them.
How are you doing iplayer through it?
Using an ubuntu image http://www.stephenford.org/joggler/
This is regular ubuntu: http://www.fuzzylogic.co.uk/
Development has been idle on both of these images for months now but they work well.
Someone has recently managed to get an ubuntu 10.04 image working, main issue being Intel and lack of GMA500 drivers, probably why the other guys gave up.
http://www.joggler.info/forum/viewtopic.php?f=36&t=1304
isnt there an ubuntu distro specifically designed for small screens? im sure i read about it somewhere...
TG
Yep, the first link I posted is ubuntu netbook edition, but you can't increase the width of the scrollbar on the main screen, the menu bars are all too small, and the onscreen keyboards that are available are fairly poor. It's good but not perfect.
Android on it is brilliant, except the graphics drivers suck, like really really suck. Otherwise I think it would be the perfect OS to throw on them.
