27 Sep 2011 at 11:39 #1 Shelster Shelster Associate Joined 3 Aug 2003 Posts 2,028 Location Plymouth, UK Would it be do-able to use this instread of the O2 wireless Box II that came with my broadband? Also, if it is, how do you go about setting it up to work? Cheers
27 Sep 2011 at 11:49 #2 Demon Demon Soldato Joined 22 Oct 2002 Posts 8,672 Location Near Cheltenham That should work, I use a Netgear DG834N ADSL2+ Modem/router to connect to O2, IIRC, you don't need any password/usernames to log on, there are several forum posts around on people that have got it working.. http://forum.o2.co.uk/viewtopic.php?p=6975
27 Sep 2011 at 12:15 #3 iamtheoneneo iamtheoneneo Soldato Joined 15 Mar 2010 Posts 11,549 Location Bucks yes but remember to keep your old box else o2 will charge you £20 if you dont send it back
