I recently got o2, and with them got a wireless router, but im not using the wireless because i previously had all wiring set up and could connect to xbox live fine.
Now i have this router i cant connect tho and dont know why or what i have to do to the router, the tests on the xbox say the ethernet port is connected but no IP can be found
It syas your console was unable to resolve a lease with your DHCP server : make sure that the addresses are available on your server.
Then it says check that no other devices have the same ip
and also check that the router is DHCP enabled :/
These are the devices found on my admin pages,
I renamed the one which is active when the xbox is on to XBOX360 but theres another unknown device there which i have no idea what that is and its says its not active.
Has anyone got this router and managed to resolve a similar issue ?
thanks
Nick
thanks
Nick
