I'm pretty sure I already know the answer to this.....
One of my tail lamps failed on the way home last night, so I swapped it with a spare that I carry.
Trouble is, the bulb is a 24v item (for a truck) not 12v and the OBC still reports "Tail Lamp Failure"
Guessing - I assume that this is due to different resistance between the bulbs?
I'll try to get a 12v bulb on the way home although tbh there seems to be little if any difference between the brightness of the two.
