Objectdock vista 64 start menu help
13 Oct 2006
Surrey
As far as I am aware, it is not possible to use the start menu shortcut in 64bit vista as yet. This to me severely compromises the software which is annoying as it work perfectly other than this issue.
Is there a hack at all I can use to sort this out, or a way to create my own shortcut to run the start menu?
Cheers
I'm sorry what are you trying to use?
If you're on about Startup that works fine on mine as does Object Dock (on both Vista x32 and x64). You can create your own shortcuts and then drag them into Objectdock?
I'm really sorry I don't know what you're trying to do?
M.
Well theres an option to add the start menu to the dock - ie have a button that opens the start menu when the taaskbar is hidden. This doesnt work in 64bit vista and so I was wondering if anyone had made it work or if theres a way I could do it manually by a shortcut?
