- 18 Mar 2007
Not sure if this should be in games or hardware……..is hardware related though...
My system spec is the following
E6600 overclocked to 3,004 Mhz
BFG 8800 GTX GPU
2 GB Geil ultra low latency RAM PC6400 800
Am really getting into Oblivion, but really expected my rig to handle it better!
Using the following settings – no mods, downloads etc – game at stock.
Am running it at 1920x1200.
Textures large
Aa x4
Bloom lighting
All shadows on
Water reflections on
Water and shadow detail to high
Grass distance about 75%
See far off objects
Specular distance about 75%
All other sliders on about 50%
I’m finding that I can’t just put everything on max and would have thought I would have been able to – is there something wrong with my rig?
At those settings it runs smooth and fast – if for example I turn the grass distance to max though, this slows things down – not unplayable but more makes it a bit stuttery. Does this sound normal?
Want this game to look it’s best. I suppose the 1920x1200 is the problem area?
Any help pls!
Nic
BFG 8800 GTX GPU
Textures large
Aa x4
Bloom lighting
All shadows on
See far off objects
Any help pls!
Nic
