hi
can any one help me making a custom build for my new char. Im planning on Mostly using a bow and a sword, (sneak behind an enemy using detect life, get off a couple of arrow shots and then when there near switch to sword to finish them off) So marksman, Blade, sneak would have to be on my majors.. but what about attributes? Obviously Agilty, but should i add speed and Stength to it? Mostly on my builds when i level i put points into two Atts and one into luck. (e.g if im a mage 1 point into Willpower, one into int and one into luck) So should i leave speed and add the points to luck? or just leave luck out
So this is what im kind of looking at, at the moment.
Sneak,
blade,
Security
marksman,
Mystisim
Light/heavy armor
Now im not sure if to add athletics and acrobat into the 7 as im planning on using the sword (nojumping to higher levels to shoot the creatures with an arrow) Im going to be using Alchemy too but dont really want that on my 7 Majors.
Also what about armor? Should i go Light armor or heavy? Sorry to be such a noob lol
Sneak,
blade,
Security
marksman,
Mystisim
Light/heavy armor
Wasnt sure about the blade/melee tho
. May as well turn the difficulty right down and console edit your way to glory.
