Mp4 said:What spec system do you need to run oblivion flatout with no glitches or gfx lag etc.
My athlon 3700 and 7800GT can run it well enough in high graphics. A few things are turned down a bit but it's on the high setting.Mp4 said:thats fair enough about an uber system , i have an athlon 4800+ dual core , 2gig ram , 2x x1900's so will that run at med settings okay? cant decide if i should get it or not really :E
I'm trying to hold off on spending more money and the temptation to get my first X1900 is getting to great
Tell me it's worth doing
The master card will have to come in september when the prices drop some more.
pc's for the win
nO}{8 said:a 7900gt with a 4800+ will run it at medium settings reasonably well (15fps minimum in out door areas) , but not really well. a 7600gt and a 3700+ will run it at lowish settings ok. as stated previously there is no system out yet that can run it flatout perfectly.
I run it on a A64 3700+ @2.8, x1900xt 2 gig ram, everything MAXED 40+ fps easy, in the 100's indoorsCombat squirrel said:why is everyone sayin dual graphics stuffI run it on a A64 3700+ @2.8, x1900xt 2 gig ram, everything MAXED 40+ fps easy, in the 100's indoors
