oblivion patches
1 Dec 2006
Amsterdam, NL
ok, i need a link that has all the oblivion patches on, from the oldest to latest so i can download them all, because im having some problems
thanks
ags
hmmmm, thanks, but its as i thought, same problem
i cant update oblivion, everytime it does, just says it found a certain file, but its not right or something....
i replaced the original exe with a cracked one so i dont need a cd (i lost it), maybe thats why
ags
just reinstalled, kicked my self in the shin, forgot to backup my saved games lol
had over 40 hours of gameplay done :mad: :(
oh well, start from fresh i guess
working now though
ags
ok, now to see if you guys can give me a hand on this one, when ever i have external/internal shadows enabled, if there is more than 2 npc's about, my frames drop a lot.... and its noticebale and very annoying, and the shadows on the npc's faces are anyting but fine.
ags
ags
you need to download the correct geographical region patch version or you get that message.
ags
could it have anything to do with the insane resolution you have in your sig.... :eek:
nah its just because he's buggering around with no-cds which aren't the same size as the patcher expects.
What I don't get is -
just reinstalled,.........
Find your missing CD did you :p
