OBS Going Out Of Sync
15 Feb 2008
Hi,
I have a Elgato HD60Pro capture card and use OBS Studio to record. Lately have notice that randomly it will start going out of sync. Videos are about 20 minutes long and start ok.
After a few minutes it will go oos by a few milliseconds, not 100% noticeable unless you look for it but I know it is.
The elgato software works ok but I prefer OBS due to the more options available.
Any ideas on sorting this please?
You can change the offset in OBS to do with voice somewhere I just can't remember where it is. Try a Google search for it and you should turn up results.
Stoner81.
Sometimes audio sync issues are caused by mismatched audio sample rates.
Everything in OBS was left at default apart from video bitrate so could be right.
Although it wouldn't explain the sync problem in game capture software as I don't think you can change this.
Will take a look cheers.
