Obsidian 700D Noise
Do you mean the standard fans that come stock? Noise from all cases can be reduced with better quality fans and sound dampening kits.
I suppose it really depends on what you are used to.. For me the case was nigh on silent.. The rubber grommets do a good job of making sure there are no noises from vibrations, however there is no reason why you cant slap a few better fans in there to kill the noise completely.
