Obsidian 800D case fan upgrade
8 Mar 2010
TBagTowers
I have allready upgraded the stock rear and added 3 top fans.
Have had a few problems with temps and it seems the stock cool air intake above the psu bay is not doing a good job, can someone reccomend a top notch 140mm fan, the ability to move as much air as possible is my priority i dont mind a small amount of noise.
Thanks all much appreciated :)
I was going to do the same only thing that I have found that would suit my needs are these really :)
140mm Sharkoon System Fan Series
• Dimensions (mm): 140x140x25
• Fan speed (rpm): 1500
• Airflow (m³/h): 140.7
• Noise level dB (A): 33
