OC forum size?
Suspended
17 Mar 2006
Question to don/admin- just how big is the entire oc uk forum (the amount of space used) hundreds of megabytes? Gigabytes? Do you use compression to save space? I assume NTFS compression should compress it quite well since it's basically just text.
