Hi all i have a 2500k cpu and asus p67 pro mobo, its running at stock and as you are all aware its built to OC , i have no idea how to tho, so if anyone had a good step by step link somewhere with the same setup as me i would appreciate it.
as you can tell i havnt overclocked before and i have the Efi bios. thanks
For some reason in cpu-z my core speed shows 1600mhz, i should be running at 3.3mhz stock correct ?
is there some kind of setting in my bios that makes it run at 1600 ??
sorry for the noob questions but im trying to learn this stuff.
