OC i5 sandy & high temps.
28 Sep 2010
Hi, i can manage to oc to 4Ghz on my standard intel cooler but the temp goes from 24C idle to 72C (after a minute or so) where i stopped the prime95 test as i dont want it to go any higher.
Is this a classic case of the heatsink not installed properly? It doesn't seem loose in any way:confused: Not enough thermal compound? I only put a thin smear on.
I shall edit later with bios voltages & settings.
[Edit]
Ai Overclock Tuner = Manual
BCLK/PEG Frequency = 100.0
Memory = DDR3-1600MHz
EPU Power saving mode = Disable
CPU Voltage = 1.168v Offset Mode
DRam Voltage = 1.525v
CPU PLL = 1.800
Cpu Power Management
CPU Ratio = Auto
Enhanced Intel Speedstep tech. = Enabled
Turbo = Enabled
Turbo Ratio = Max Turbo in OS
Max Turbo Ratio = 40
Also I have just reseated the cooler but there looked to be a nice even coat of compound on the cpu & hs. I've not tried to run prime again yet until I know the settings above are correct.
Thanks in advance for any help/advice.
Asus p8p67 pro, i5 2500K, Corsair XMS3 4GB @1600
Thanks that was a quick reply while i was editing RJC :D
Yeah i appreciate the stock cooler is a bit poor & a new cooler is next on my list. I was mainly concerned with the temp. Not sure what the safe max is so didn't want to leave it.
If my settings above are fine then I can leave them 'as is' until i get my cooler. Hopefully at the end of the week.
