- 6 Jul 2016
Hey everyone,
The last week I've been toying with overclocking my CPU on my new rig.
I did a lot of research before hand to try and wrap my head around overclocking. I've been using Core temp and CPUz is it ? to watch my temps and such while using Prime 95 to test the cpu.
My stable 4.5 at 1.35 - NO XMP
I managed to get 4.5 stable without XMP running on the ram at 1.35v and passed all tests on a torture test over 12 hours of prime 95. I played trying to get the voltages down but my attempt at 1.34 failed after 2 hours on core 4. Temp wise I was maxed at 72c. usually between 61-69c over the 12 hours.
Voltage question
My worry is that the voltage never seems to stay at 1.34 the VID (which I believe is the voltage I've set to be 1.35?) seems to move around from 1.23 - 1.36 a lot which could be causing a lot of issues? from what I understand I can use LLC for this however my motherboard has this stuck on Auto, hitting enter won't let me change anything or bring up any menus. Is there something else I could change or adjust for this?
- Gigabyte Gaming k3 z170
- i6600k (going for 4.5 stable)
- h55 corsair AIO cooler
- 3000mhz DDR4 corsair LPX 16gb (XMP attempts)
- MSI gtx 1060 gaming x
- 500 W Corsair bronze + PSU
- 250gb SSD Samsung 850 evo
- 1tb WD Blue 7200 rpm
Voltage question
- I'd like to use XMP to get my memory clock off of 2133mhz to 3000mhz or is this a bad idea and just ignore XMP all together? (does this affect my voltage to cpu also?)
- How can I enable LLC in a gigabyte gaming k3 to switch it off auto?
- Anything else I should look for that could affect my voltage while overclocking.
- Should I just enjoy my 4.5 at 1.35 without XMP and call it a day?
. I'll play with this for now and create a new profile to gradually lower the voltage to see if it can handle it any lower (I doubt it was close before). I wont play about with my graphics card overclocking just yet as I think that'll push my PSU to far I imagine (500w bronze corsair something something).
