Hi 8pack. You helped me in an earlier thread about stuck voltages on a P35 board. Ive not had a chance to fix it just yet
because i need to get the new pc up, running and stable...
Hardware:
GA-Z77-D3H (rev1)
i7 3770k
Samsung green 8gb ram (Stock Volts & timings)
Gelid tranquillo cpu cooler (rev2)
Seasonic x-650 psu
BIOS Settings:
MIT/Advanced Freq
CPU/PCIE Base Clock................: AUTO (Set to 100 or leave AUTO???)
INTERNAL CPU PLL Over voltage.: AUTO (ENABLE when reducing PLL values or on regardless???)
Advanced CPU CORE Features
INTEL Turbo Booster Tech.......: DISABLED
HYPER-Threading Tech.......,....: ENABLED
CPU ENHANCED HALT..............: DISABLED
C3/C6 STATE SUPPORT...........: DISABLED
CPU THERMAL MONITOR..........: DISABLED
CPU EIST FUNCTION...............: ENABLED
Advanced Volt settings/3D Power:
PWM Phase Control................: AUTO
Vcore voltage response..........: AUTO
(v) LLC................................: HIGH
GFX....................................: AUTO
Vcore protection...................: AUTO
Vcore current protection.........: AUTO
GFX current protection...........: AUTO
Vcore Thermal protection........: AUTO
CPU Voltage Control:
CPU vCore..............: 1.105 #1.240 got me to 4.6
CPU VTT................: 1.060
CPU PLL.................: 1.800
CPU IMC.................: 0.925
Action Plan:
Objective is to increase cpu core freq and adjust vcore when needed. Not interested in voltage offsets or power saving features so i believe they are all disabled. With the info ive gathered at OCUK ive managed to get it to 4.5ghz so far. Temps are low enough that i could go further but something via mobo is still handling vcore without my control. Could the LLC be responsible? I set it to high with the idea to cover any vdroop during load. Vcore was left at stock 1.105. Up until 4.2ghz it seemed fine but i noticed the sudden jump to 1.235ish around 4.4. To reiterate, im not sure what controlling vcore because i certainly didnt set it to that value. Heres some images. ***UPDATE: FIXED***
4.3@IDLE &4.3@LOAD
4.4@IDLE & 4.4@LOAD
At the very least i know i can get 4.5ghz with vcore of 1.25ish. Still, id rather have complete control over it instead of some automated bios feature. ***UPDATE: FIXED***
Id Also love to go over reducing PLL Voltages and the appropriate amounts.
Please let me know if theres anything else i can include. TIA!
Hardware:
GA-Z77-D3H (rev1)
i7 3770k
Seasonic x-650 psu
BIOS Settings:
MIT/Advanced Freq
Action Plan:
4.3@IDLE &4.3@LOAD
4.4@IDLE & 4.4@LOAD
