oc i7 920
16 Nov 2008
West Sussex
just oc my 920 i7 to 3.2ghz. running prime temps are up to 59c does that look a bit hot of not? whats the max temp for these cpu?
As long as it's stable running Prime95 and not throttling you'll be okay, i7's seem to run fine at temps most other CPU's would melt at. :p
Mine doesn't even seem to run all that hot (when touching heatsink) perhaps it's just a temp sensor thing, either the sensor is more accurate or it is set artificially high in order to scare overclockers.
