OC look ok?!
15 Nov 2010
So I'm running a sever Xeon X5650 (2.66Ghz) OC'ed to 4Ghz in a Asus Sabertooth X58 mobo.
I have 6gb Corsair Dominator 1600mhz ram.
So I made my BCLK 200x20 and then ram runs 1600mhz too :)
I set Real Temp to TJ Max to 90 instead of default.
The test seen here ran for 3 hours, well just short.
On Prime95 I did In-Place large FFTs (Max Heat) for this test.
Seems to be good and stable enough?
Should I test it further or for longer?
If so what test and for how long?
I read or heard somewhere that IBT was pretty strenuous so dont exceed 20 loops.
Should I just run 15 loops to be slightly on the safe side?
