OC Memory Question
6 Apr 2007
Manchester
Hi,
I currently have:
FSB: 389
Multi: x9
Vcore: 1.425
NB: 1.71
CPU Clock = 389 x 9 = 3.5Ghz (Orthos Stable 10+ Hours)
Memory Timings: 4-4-4-12
Memory Strap: 533 1:1
Memory Speed: 389Mhz
My problem is when i try to increase my FSB to 400 so that my ram will run at 800mhz like it is suppose to do system will not boot, even at higher voltages.
If i change the CPU strap in my bios to say 667 then this runs the ram at like 975mhz which it cannot handle :( so is there any way i can get my ram to run faster? or at least to 800mhz? on this overclock? or do i need new ram?
Ram is in my sig, it is 2GB OCZ Platinum 4-4-4-15 Dual Channel Kit.
Thanks
Yeah tried them at 5-5-5-15 but still no good, any ideas how to chnage them to 2T timing on my board? can't find the setting for it?
