Read an interesting article on toms http://tomshardware.co.uk/2006/05/10/dual_41_ghz_cores_uk/
where they OC a 2.6ghz pentium D to 4ghz and it runs stable.
now I imagine some of the hardcore oc'ers out there will probs be able to push this higher with water cooling etc.
but i was wondering which air cooling solution you lads might suggest for this bad boy?
I was looking at The scythe Ninja with a 120mm cooler.
edit : at 4.0ghz they recommend water cooling in the article so i'll only be going for an O/c of around 3.2ghz
