- 18 Oct 2007
hi
My PC:
MOBO=Asus P5N-e SLI
BIOS=0703
CPU=E6600 rev B2, big Zalman Copper (CNPS9500 AT)
CPU CORE VOLTAGE=1.328 (by setting auto bios overclocking to 10%)
CPU MULTIPLIER=9
CPU BUS SPEED=293Mhz
RAM=PC5300 Patriot 2GB (2x1Gb) DDR2 667MhZ Extreme Performance
RAM SETTINGS= 4-4-4-12
PSU=Thermaltake 600W PurePower RX ATX 12v 2.2
CASE=Antec Nine Hundred
GPU= 8800GT
OS=Vista 32
Using CPUZ, nTune, and Bois
Im only using the BIOS automatic OCing at the moment and im not getting far with the CPU OCing
i can clock it 15% and its stable, but when i OC the GPU o have to put the auto OC for CPU back to 10% for stability
Im overclocking the GPU with nTune settings
mobo PCI-E from 2500 oc to 2700
GPU core bus from 600 oc to 656
GPU memory bus from 900 oc to 1000
These GPU settings make a nice difference to games, but then i can only get my CPU up to 2637Mhz (or 10% in bios)
I havent really changed any Volts as i cant find a good enough guide
What i really need is some help about has anyone got any good guides or done this before with this setup.
Appreciate any help thanks
Simon
My PC:
MOBO=Asus P5N-e SLI
BIOS=0703
CPU MULTIPLIER=9
GPU= 8800GT
OS=Vista 32
Simon
