Oc Pre built ....?...
5 Aug 2011
Costa del glasgow
What is better is the bettter option to build my own system choose my own spec or go for oc pre built .?
Better value for money is what I mean ?
A Sandybridge system is so easy to overclock it seems a waste not to have a go yourself :)
Plenty of advice to be had here on the forums if you need help. You can likely easily get 4.5GHz with 2 or 3 option changes in the BIOS/UEFI on a 2500k with a half decent cooler for example.
Nice one cheers
