I was curious about my RAM settings after looking in CPUZ so i looked in the BIOS:
First thing i noticed was that the PCI EXPRESS CLOCK was at 101Mhz?
Secondly, that the RAM was operating at DDR900 (more or less). The system i got from OcUK has Corsair Dominator 4GB PC2-8500 which is 1066? Its in a 4x1GB Config.
Here is the rest of the info (from the BIOS) incase it helps:
System Specs Here: http://www.overclockers.co.uk/showproduct.php?prodid=FS-005-OC
External Clock = 358Mhz
Multiplier Factor = 9
DRAM Speed (CPU : DRAM) = 1:1.25 (DDR2-895)
PCI EXPRESS CLOCK = 101Mhz
VOLTAGES CONTROL
Voltages Control = User Define
CPU CORE VOLTAGE VID = 1.4500 V
CPU CORE VOLTAGE OFFSET = 0.0000 V
DDR2 Voltage = Auto
CPU VTT Voltage = 1.25 V
MCH 1.25V Voltage = 1.30 V
ICH 1.05V Voltage = 1.10 V
ICHIO 1.5V Voltage = 1.55 V
DDR Reference Voltage = DEFAULT
CPU GTLREF 0&2 = 67x
CPU GTLREF 1&3 = 67x
DRAM Timing Selectable = Manual
CAS (tCL) = 5
RAS# to CAS# Delay (tRCD) = 5
RAS# Precharge (tRP)= 5
Precharge Delay (tRAS) = 15
