OC Tech Labs Watercooling Kit Question
29 Oct 2012
I was looking at moving into water cooling and noticed the v8 and v12 all say that they have 1 fan, i assume the double rad kit actually has 2? and the triple rad kit has 3? and do these kits need to be cleaned/flushed through before use? or have they already been cleaned?
also i wanted to cool the cpu only first, once i get the hang of it i would like to start moving into full water system cooling, GPU then expanding. would the v12 be a better option for this?
last but not least i am interested in either the NZXT Phantom 630 High Performance Modular Ultra Tower Case, http://www.overclockers.co.uk/showproduct.php?prodid=CA-123-NX&groupid=2362&catid=35
or the Phanteks Enthoo Luxe Full Tower Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-PT
would either of the cases be suitable for the above v8 or v12 water cooling options?
Thanks in advance for any help with this.
Rule of thumb is this. 360 rad, x3 fans. 480 rad x 4 fans, 240 rad, x2 fans ect ect
And no im pretty sure you need to clean them yourself, they are just bundled up for price.
Although tbh I was going to get the w12 kit, but I decided to spend extra and get it app separate, whilst yes indeed it did cost more, I found I could choose my cpu block, pump/res sixe of fittings, what type of fittings I chose. its a shame, it was the deciding factor, as the w12 kit almost looked perfect for me.
Im also looking at the V12. I would need it to cool an oc i5 haswell and an amd 7990. Would this be sufficient to cool both of these or would i need to add another rad?
Thanks
