Recently got myself a q6600 and decided to give overclocking a shot, first time i'm having a shot at it so i aimed my targets for 3ghz which seemed to be a reasonable overclock.
My first concern is the temp, after only three mins on Prime95, i'm worryingly receiving rather high temps in core temps and using speedfan... and confusingly am receiving a 15 degree difference in the two applications!
http://www.firestorm3d.co.uk/random/temps.jpg
Using a TR ultra 120 extreme, 2 120mm fans already in the sytem and on an Abit IP35 Pro mobo.
Could anyone advise which of the two temps recorded i should be following, and secondly any advice on how to drop this cooler? It's not a huge overclock or anything like that and so I wouldnt really expect such temps after 3 mins, i'm currently pondering about re-seating the cooler, though initial glance seem to indicate that it's seated fine. Using Vista 64.
Any advice would be great =)
