OC, where is enuff?
Jokester said:
Might shorten it a bit, but by the time it does die you'll have likely upgraded to a 64 core 10GHz monster.
Jokester
Rofl.
I bought a 1Ghz Tbird a few months after they were released. I did the pencil mod to unlock the mulitplier. I OC'd to 1463 Mhz 133x11. It was my games machine until it became a PDC and file server still clocked at 1463Mhz around 3 years ago, when it began running 24/7. The Tbird is still running 24/7 as an AD master and file server. Same cooler, same fan (Taisol), same TIM (arctic silver), same pencil mod (HB). It's had the cat fur blown out of it a few times :D
It will most likely reach a recycling plant before it fails
okie, thats nice.
hmm btw, i'm able to get this, but which is more efficient?
2.7Ghz - 180
2.8Ghz - 166
2.9Ghz - 140
Considering between 2.7 and 2.9, should i go for better ram speed or better cpu speed?
those are the divider that i set..
but if i set a divider of 140, it will be running at around 230Mhz, should be okie yea?
Yeah, if that's the divider settings the (I'm guessing) RAM speed in each of the cases is going to be much the same so definitely go with the CPU speed.
Jokester
