Hi guys,
I'm hoping for a little help here as I'm a little puzzled.
I have had my PC since the summer running a 3570K at 4.7GHz on a Gigabyte z77-ud5h motherboard with Avexir core blue 2666 (2x4gb).
Now it boots fine and works fine for most applications, however WoW crashes after long periods of play and BF4 does with short periods of play. These crashes sometimes result in BSOD for memory requiring a reboot. Now wether the reboot be manual or forced, it fails to post and comes up overclock fail. If I turn off the computer or simply leave it for 10 mins it will boot again no problem. The CPU never gets above 55-60 and the ram is still very cool touching by hand. I can turn down the ram speed to 2200 and the fails stop. I have ran MemTest86
From a USB boot and the ram does not show any failure. I understand the simply fix is to lower the speed to 2200, but I didn't spend the extra ££ to run it at a lower speed.
Any help would be greatly appreciated!
Thanks
Thanks
