I've been having a few problems with the PC at the moment, so thought I'd check the PSU. The voltages are miles out - esspeacilly the 12V rail. (Will get the multimeter out tomorrow to confirm).
Is this normal? Does the voltage drop if the current pull is low?
I can run GPU & CPU stress tests at the same time without issue, but every now and again I'll get a BSOD while playing GTA5. BSOD 124. All overclocks have been removed.
