OCCT i7 3770k Question
18 Oct 2012
Hello all,
I have recently downloaded OCCT and ran a 30 min test, 64 Bit, Large Data Set, 8 Threads without an overclock. (Well, it says a 71.1Mhz more than turbo speeds, so 3571.1Mhz)
I look at AI Suite II Sensor Recorder and its only 42*C. Is this normal?
When not under load, the temp jumps between 29*C and 32*C. 10*C difference, is that all?
Just a side note, I flipped the rad around so the pipes exit at the top of the rad, is that safe as well?
Test failed after 17 mins, temp still 42*C.
Love to hear your feedback,
JCX50
the aisuite temp is the socket temp not the core temp grab coretemp or realtemp to find out what the real temps are
