OCCT - LoadDriver Failure!
21 Oct 2002
Wellington, NZ
Thats the error message I get when I start OCCT, anyone know what it is? It also fails the test after 3mins even at stock:o
I didn't know if the error message is related to the test failing? I thought my system was pretty stable tbh.
Tim, have you configured OCCT to monitor you temps/voltages with monitoring s/w? It asks you when you first run OCCT what monitoring s/w you are using(either MBM5, Asus PC Probe or SpeedFan or none).
If you have input that you use one of the above, that needs to be installed and running when you use OCCT.
HTH, dagwoood.
OCCT Does not like DEP in windows XP SP2, either disable it or add it to the exclusion list. then it should work fine as i used to have that problem at stock also.
Yeah its all set up correctly, I run speedfan at the same time... sorry i'm not sure what DEP is.
I reckon the problem is because I'm using Win XP Pro X64. its not a major problem as its prime and game stable.
