Occulus arrived - but software will not install
20 May 2010
World
Only got as far as downloading the occulus set-up
When I run it , it tell me I need windows 7 64bit ..... which is what I am running (all windows updates are up to date)
Anyone else have issues with this ?
Got it sussed and the software is installing
It said I needed 2 updates
Windows6.1-KB2670838-x64
Windows6.1-KB3033929-x64
Which when I downloaded from MS and ran the installers which reported back ..... update already installed (for both)
Had to use the below documented method to force re-install these already installed updates ....
http://blog.tiensivu.com/aaron/arch...g-a-.MSU-package-in-Vista-or-Server-2008.html
Just documenting this here incase some other poor bugger has the same issues
Edit: Thanks for the help guys, really appreciate it
