OC'ers triple monitor stand
14 Sep 2012
Behind you
Iv'e just set up my triple monitor stand ( http://www.overclockers.co.uk/showproduct.php?prodid=MO-009-OP ) and I'm having trouble in getting the screens to sit level, they keep wanting to tilt downward. I have tried to tighten the alen bolts but they are huge, I've got 4 set of alen keys but none that big, so I tried with mole grips, but they are as tight as they will go.
Has anyone had the same issue, and have a fix ? Or am I missing something ?
Hi there
You need to tighten the bolts with allen keys and put some effort in, once tightened the monitors will no longer tilt.
Mole grip won't give you enough leverage or grip, pop to Halfords and get a set of allen keys and check the packaging to see if any allen keys were supplied.
