65nm instead of 6x0's 90nm process.WJA96 said:Yes, 6xx series are fabulous clockers. THe best are the 6x1 series although I can't remember why, but they run super-cool.
Renember you need an ultra stable board that sustains 1.525 most of the time or at least 1.51, i have an asus with the famous vdroop i only managed to boot @ 4.7 with 1.575 in bios ( but im afraid of overvolting, this was only for testing, especially afraid cos i only have a freezer 7 pro, temp was 65ish C when at that voltage when idle) , wich was actually 1.502 in real, tehres this guy on ocuk i forgot his name wich has a prime stable air cooled p4 630 (i have a 630 too ) @ 4.7 also, offcourse for those speeds you need 1: a very good air cooler: scythe ninja at least, or water,, water wont let you go much higher i think as i renember p4 limit on some site iwth sub zero temps was 5.25 ghz or something, wich was on 1.7 volts and liquid nitrogen, whataver the case, its hard to keep it at 4.7 ghz but possible, perosnally i'd go (if i had the choise again) for a pentium d 805 and oc it to 4 ghz.turboshed said:the one in question is a 670, my friend is thinking about upgrading to a conroe and he said if he does i can buy his chip from him, 4.7 on air seems nice, how about on water, do you reakon it would break 5ghz
matt100 said:its hard to say, phase would probably manage it but I'd be suprised if you could get it over 5ghz with air/water.
Truth of the matter is a well clocked e6300 (3ghz+) would probably still show a 5ghz p4 a clean pair of heels. I certainly wouldn't be wanting to exchange much more than say £100 for one of them.
monkeypants said:65nm instead of 6x0's 90nm process.
