OCing a 2070 S
20 Jan 2017
Never been confident in trying to overclock but I would like to try and push my gpu slightly. I only really use my PC for sim racing but I occasionally stream. I have to reduce the settings when streaming so I was playing with the idea of maybe asking a bit more out of the gpu.
Not sure if it's needed but here's my setup:
R5 5600x
MSI Gaming X 2070 Super
Asus Tuf gaming B550 Plus
16GB 3200Ghz
650W Corsair TX-M series
Can anyone help me on what I can do please?
R5 5600x
16GB 3200Ghz
All you need to do is install MSI Afterburner and do everything within that software. Don't be afraid to tinker with it as you can't damage the card in there (except make sure you don't manually set the fans too low and overheat the card). Generally you might want to boost the core clock a little (+100 to +500) while boosting the memory clock often yields the best results.
If you lookup 2070S overclocking on Google or Youtube there will be hundreds of guides for other owners' optimal settings for your GPU.
