Can anyone offer some advice I am very out of date.
I have 4gig of this stuff https://www.overclockers.co.uk/showproduct.php?prodid=MY-124-CS
Should I be telling the board it is SLI compliant - what would you advice me to set everything at to start optimising it I have the voltage set to 2.15v currently the timings set to 4 4 4 12 (took me a while to learn you had to up the voltage to not have default 5 5 5 15 timings!)
Byt the way what does SLI compliant mean - how does that work?
Shoudl I try running it faster than 800mhz as I can set this straight from the bios -I am running the cpu unlocked the the memory does not get artificailly dragged up with overclock (I think)
Thanks
STuart
Thanks
STuart
