right ive finally finished my crysis rig
q6600 go gtx 4 gig ballistix 5300 ip35-pro
ok so everything was running ok core temp showed 22c on all cores. tat doesnt run for some reason. anyway played moha and crash crash crash. and core temp then stopped working every time i opened it it reset my system instead of showing temps. so i was looking in voltages in guru it showed cpu at 1.2875 i think and mem at 1.8v added volts to both but still the same. today i ran orthos and it failed within 2secs. read up here to increase voltages more which then spurred me on 2 find the volt spec for my memory. it is 2.2v!!
i had it running at 1.8 v1.9 at most. changed to 2.2 and no more crashes core temp works again although now cpu at idle is 27c?? uguru still shows 19c like it did when core temp showed 22c.
anyway i tried ocing a bit but failed, cpu-z confuses me. i got a calculator out and tried to make sense of things in regards to fsb/ fsb/dram bus speed multi. i started to see some patterns. cpu-z says one multi bios says another? the speed is out too i think. when i oc to 3ghz the rated fsb said 1260. after about 20 secs it just hung. also cpu z says 4:5 fsb dram. is that a ratio? does it mean memory is running 4/5ths the speed of cpu or sumet?
if any1 has got any quick advice i would much appreciate it......will be going out now so will try to oc at 11 tonight
RAM . thats the one right. i will age up and down on it until i find 1:1.
