Permabanned
- 28 Feb 2007
- Somerset
Right, I'm having problems trying to get my overclock stable with Orthos, I'm currently at 3.2GHz at 1.5 Vcore, (1.6 in the bios, 1.54 Idling.)
It seems perfectly stable in everything else besides Orthos, for instance playing games, running 3DMark06 CPU tests, Super PI etc are all fine.
My temps seem fine, 35c Idle and 57-60c on load so no problems their.
When at 3.2GHz.
3DMark06
Super PI
CPU-Z
Orthos STOPPED
Temps, Idle
Temps, Load
In case its helpful...
I can also lower the Vcore right down to 1.525 In the Bios and again everything's fine expect for Orthos failing so i raised the Vcore 3 more times and now I'm thinking I've missed something or doing something wrong here as i would have thought its plenty of Vcore.
My RAM should be fine as I'm running at 1:1 so atm its currently running slower that its rated speed and running at 2.1 volts, so i dont think thats a problem.
I've also upped the NB voltage by 0.3, yet still failing Orthos.
RAM/Motherboard in Sig, cooler is a ACF7 Pro.
Any idea's or suggestions, thnx in advance.
When at 3.2GHz.
3DMark06
Super PI
CPU-Z
Orthos STOPPED
Temps, Idle
Temps, Load
