OK, so I have just got this rig up and am beginning to see how far I can go.
It seems not too far. I have (sort of) made 3150 MHz (450 MHz FSB, 1:1) but not (yet) 100% stable. It dropped out (crashed) after ~1 hour of dual primes (how do I include a screen shot?).
However, it just won't even POST at 470 MHz FSB or above. No beep, nothing. Power off and I get the failed overclockinhg message. Asus recovers well though (no CMOS clearing necessary - phew!).
Figures as below - any help?
Software / Firmware
Component Make/ Model Specification / Revision
BIOS American Megatrends 711
Windows XP Professional SP2
Settings
Menu Sub-Menu Setting
Main
IDE Configuration
SATA Configuration Enhanced
Configure SATA as RAID
Advanced
Jumperfree Configuration
AI Tuning Manual
CPU Frequency 450
DRAM Frequency DDR2-900 MHz
PCI Express Frequency 100 MHz
PCI Clock Synchronisation 33.33 MHz
Spread Spectrum Disabled
Memory Voltage 2.15 V
CPU Core Voltage 1.35 V
FSB Termination Voltage Auto
NB VCore Auto
SB VCore Auto
ICH Chipset Voltage Auto
CPU Configuration
Modify Ratio Support Enabled
Ratio CMOS Setting 7
C1E Support Enabled
Max CPUID Value Limit Disabled
Vanderpol Technology Enabled
CPU TM Function Enabled
Execute Bit Disable Enabled
PECI Disabled
Chipset
North Bridge Configuration
Memory Remapping Feature Disabled
Configure DRAM Timing by SPD Disabled
Memory Timing Parameters 4, 4, 4, 12, 6, 42, 10, 10, 10, 10
Static Read Control Disabled
O/C Testing
Tool Value Value
Prime 95 Torture Test x2 825 MB memory
Intel TAT (v2.05.2006.0427) CPU temp - Idle ~ 44 Deg. C Load 59 Deg. C (max)
Core Temp (v0.93) CPU temp – Idle ~ 45 Deg. C Load 62 Deg. C (max)
Asus Probe (v1.01.16) Motherboard – Idle ~36 Deg. C 43 Deg. C Load (max)
VCore - 1.288v-1.3v
Speed fan (v4.31) CPU temp– Idle ~ 45 Deg. C Load 50-57 Deg. C
Cpu-Z Core Speed ~3150MHz
Software / Firmware
Settings
Main
IDE Configuration
Advanced
AI Tuning Manual
CPU Frequency 450
NB VCore Auto
SB VCore Auto
CPU Configuration
C1E Support Enabled
PECI Disabled
Chipset
O/C Testing
Tool Value Value
VCore - 1.288v-1.3v
