Ive had a look around the BIOS, and I make up my mind and to what settings the change other than the FSB for the CPU.
So far I have changed it so the memory is 'unlinked' and have been messing around with upping the FSB for the CPU. (Also what would i set the FSB too if i wanted just get simply 3.0ghz? Im only used to OC'ing my old DFI 939 mobo lol, they were easy to OC as i knew how the CPU speed was determined, but with 775 im not sure how the speed is determined.)
Is there anything else that needs changing if i unlink the memory and change the FSB?
Thanks very much
Thanks very much
