Octo help
29 Feb 2012
London
Hi guys,
So i installed a distribution plate into my pc.
Turned it all back on, the aquasuite software/octo needed a firmware update so I did that, now in the software it doesn't recognise it.
I get this messages
http://imgur.com/gallery/rpjniuk
I uninstalled/reinstalled the software to this
http://imgur.com/gallery/9EtCuZZ
Windows sees the octo in device manager as working correctly.
I updated my bios as well.
I tested the 2 USB ports on the mobo with the rgb controller and they both work.
Fans and pump are running but i have no control over it now, not sure whats happened?
Thanks
