OCUK 24" Monitor DVI Problem
Man of Honour
1 Nov 2006
The monitor has been working fine for a few weeks using DVI now it has stopped working and it says there is no signal. I am now having to use the VGA port, which works, but is obviously off much less quality.
Is there anything I can do to resolve this?
Have you tried changing the resolution to the correct setting? Normally this is what you'll see if using a resolution the monitor can't handle. :)
Thanks for reply...
Im using 1920x1200 so it should be ok - it was working for a couple of weeks anyway?
Ive established now that it must be my old ati 9700 gfx card...ive plugged it into my (uncompleted) new build and it works fine, so its not the monitor...
