Starting to see these listed else where, wonder when OCUK gonna list em?
Cooler looks great, far better than the stock X2 cards
Designed by SAPPHIRE, the new HD 4850 X2 comprises two complete HD 4850 graphics systems on a single PCI-Express card connected by an on-board PCI Express Gen 2 bridge chip. Each GPU has 800 stream process units and a 256-bit memory interface driving 1GB of GDDR3 memory, making a total of 2GB on-board memory. Four Dual Link DVI outputs are provided as well as TV-Out. This provides a choice of Multi-monitor operation or CrossFire mode in which 3D applications such as games use both on-board GPU’s together to deliver a single accelerated output on the Primary display with industry leading levels of performance.
# I/O Output: Dual DL-DVI-I x 4 +HDTV
# Core Clock: 625 MHz & Stream Processors: 2 x 800
# Memory Clock: 993 MHz, 1986 Mbps
# PCI Express 2.0 x16 bus interface
# 2x 1024MB or 2x 512MB /2x256bit GDDR3 memory interface
# Dual Slot Dual Fan Active Cooler with Fan Speed Control
# HDMI compliant via dongle
# 7.1 Audio Channel Support
# Microsoft® DirectX® 10.1 support
# Shader Model 4.1 support
