OcUK Athena Case
13 May 2003
Hamilton
Due to me being stupidly over optimistic about planning an upgrade....
I ended up trying to fit too much into a Lian Li V351 Cube. The case is very well manufactured, although I there are some surprising gripes and the form factor is not useful.
I had also bought an Athena case to turn into a NAS. I ended up having to use the Athena case for my main build and I'm shocked to say it's turned out extremely well!
Let me be clear about a few things to start with...
1) This case is not made of expensive materials. It's thin steel. That means it's light, but it also means it's not strong at all. You need to be careful when detaching blanks, or putting pressure on things to avoid it bending.
2) The front panel audio (like any I've ever used, including Lian Li) has a whole lot of noise on the line. It makes my soundcard sound like onboard sound from single core days. Not only that but mine seems to carry only the right hand channel. The USB works fine.
3) The PCI retention tool-less thing is a bit naff. Sadly since it's made of thin steel it's very bendable. If they had made the detachable part of much tougher material then it would actually have been a good addition.
4) It comes with no fans. You'll need to put some in. 3x 12cm and a 8cm.
So that's some pretty heavy criticism. But then again I've never seen a perfect case. And this one costs £19. And there's lots of good things about it.
A) It's very inexpensive.
B) It's simple to work with.
C) It's small. Not too small, but small. I have.... an ATX motherboard (Crosshair IV, with a 1090T), 4x2GB sticks of Reaper. Cooling the CPU I have a Arctic Cooling Freezer 7 Pro 2. It's cheap and does a good job too. I have a Prolimatech MK-13 (which I don't recommend due to the massive size) on a Radeon 5870. I have 2 12cm fans parallel to the graphics card, and another over the top of it. I have added one case fan to it (I will be adding more) as an exhaust.
D) The 4 fan locations are... 12cm at the back. 12cm at the front (although since the front is solid I don't know where the air is coming from). And on the side panel there is a space for a 12cm intake. There's also a pipe which looks to be set to ensure the CPU cooler gets cold air. I removed it and it the holes are the correct size for an 8cm fan. Temps aren't great, but aren't bad. The graphics card idles at 90 in Furmark, but the fans on it run silent. Better airflow would help so I can only suggest the 12cm fan at the back of the case is the fastest you can stand.
All in all though I was stunned at how much of a rip off this case makes the expensive ones look!
Pic's pic's pic's of your build - here is the stock image
yes pics required/.
I was about to place an order for some of the ocuk cases and seems within 1 week the best looking cases are out of stock/no eta :(
Regarding your front audio issue tad strange but one thing ive noticed is a lot of the newer mobos have hd audio and some of the cheaper cases may just be standard ac97/audio... perhaps thats your issue? I assume ocuk cases dont have hd audio on the front.
So just goes to proove ocuk need to expand on this and get stock in with silly numbers cos it looks like I might have to give my money elsewhere.
wtf ocuk completely deleted a nice case for about 22-23 quid was no ETA and included a 450watter, completly taken off the webby lol
maybe too many people complained ;)
It's HD audio, rather than the out of date AC97. I should say I listen with not cheap headphones so I'm going to hear any noise at all.
I'm putting some new fans in later in the week. I'll take some pictures then.
Is this true for all cases? I was really miffed about this with my Lian Li case which cost me shy of £200 - the noise on the line is absolutely horiffic to the extent that I don't even have it wired up at all because it's an embarassment to a rig that I'm otherwise completely happy with. Sounds like when you hold a mobile phone or other source of interference up to your speakers except constantly
