So im looking at a few monitors on the clearance line and they are quite noticeably cheaper than their brand new counterparts...
So my question to you is what is the difference?? will it arrive with 183487 dead pixels (exaggerated...) or will it arrive with a slightly damaged box but everything else be perfect?
The monitors in question are as follows:
http://www.overclockers.co.uk/showproduct.php?prodid=BG-118-LG&groupid=595&catid=670
http://www.overclockers.co.uk/showproduct.php?prodid=BG-117-LG&groupid=595&catid=670
http://www.overclockers.co.uk/showproduct.php?prodid=BG-041-AC&groupid=595&catid=670
http://www.overclockers.co.uk/showproduct.php?prodid=BG-172-SA&groupid=595&catid=670
Im basically looking to make a choice between them all, and so far im edging towards either the ultrawide or the 1440p as 4k involves a lot of upgrading and spending that i dont want to do... But it is still an option
Just give me a rough idea of what im looking to receive and how bad the problem will be... If one is there...
Hope you can help me out
Many thanks in advance
(unless its just a normal kettle plug then idc)
or possibly the 1440p
