Hi there
People seem to be struggling to find DDR4 in stock, so first of all be sure to check our DDR4 section as we've never being completely out of stock of DDR4 once, we've always had something in stock whether it be from Avexir, Crucial, Corsair or G.Skill.
OcUK DDR4 MEMORY SECTION - CHECK IT OUT (CLICK HERE)
DDR4 SKU's IN STOCK NOW (24/09/2014
Crucial 16GB (4x4GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K4G4DFS8213) @ £169.99 inc VAT
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that’s exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
Load applications faster and run demanding programs without lag. Crucial DDR4 memory debuts at 2133 MT/s – more than 30% faster than DDR3 memory technology.1 Even better, as DDR4 technology matures, speeds are projected to hit 3200 MT/s – twice what was possible on standard DDR3 memory.
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial DDR4 increases memory bandwidth by over 30%, allowing your system to handle more data at once. As DDR4 technology matures, bandwidths are expected to achieve up to 25.6 GB/s – twice that of standard DDR3. To maximize bandwidth, Crucial DDR4 memory is optimized for nextgen platforms that support four channel memory.
Get better performance – using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 consumes 20% less voltage than standard DDR3 technology. Crucial DDR4 modules also contain other efficiency features, for an overall power reduction of up to 40%.
As a brand of Micron, one of the largest memory manufacturers in the world, Crucial DDR4 memory represents the future of computer performance. From the original DDR technology to DDR4, we’ve engineered the memory technologies that have powered the world’s computers for 35 years and
counting. When you choose Crucial DDR4 memory, you’re choosing memory that’s backed by a limited lifetime warranty2 and designed for the world’s leading systems. Don’t settle for anything less.
Specification:-
- 2133MHz (PC4-17000)
- CAS Timings: 16-16-16
- Voltage: 1.20v
- Warranty: Lifetime
Only £169.99 inc VAT.
ORDER NOW
Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) @ £329.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £329.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit (CMD16GX4M4A2666C16) @ £307.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- 2666MHz (PC4-21300)
- CAS Timings: 16-18-18-35
- Voltage: 1.20v
Only £307.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (CMD16GX4M4A2666C15) @ £349.99 inc VAT
Specification:-
- CAS Timings: 15-17-17-35
- Voltage: 1.20v
Only £349.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 32GB (4x8GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit (CMD32GX4M4A2666C16) @ £599.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £599.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit (CMD16GX4M4B3000C15) @ £499.99 inc VAT
Specification:-
- 3000MHz (PC4-24000)
- Voltage: 1.35v
Only £499.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit - Black (CMK16GX4M4A2666C16) @ £239.99 inc VAT
Vengeance LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom. Each IC is individually screened for performance potential.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There’s XMP 2.0 support for trouble-free automatic overclocking. And, they’re available in multiple colors to match your motherboard, your components, or just your style.
Specification:-
- Voltage: 1.20v
Only £239.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Black (CMK16GX4M4A2666C15) @ £249.95 inc VAT
Specification:-
- Voltage: 1.20v
Only £249.95 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Red (CMK16GX4M4A2666C15R) @ £249.95 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Black (CMK16GX4M4A2800C16) @ £289.99 inc VAT
Specification:-
- 2800MHz (PC4-23000)
- CAS Timings: 16-18-18-36
- Voltage: 1.20v
Only £289.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Blue (CMK16GX4M4A2800C16B) @ £289.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
G.Skill Ripjaws 4 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Red (F4-2400C15Q-16GRR) @ £249.95 inc VAT
G.Skill Ripjaws 4 perform in G.Skill typically fashion, crazy fast! Based on Hynix IC the G.Skill modules come recommended by 8 Pack himself as they have great overclocking ability and the price is always very competitive in market.
Overclockers UK is first with the G.Skill range and Ripjaw 4 is designed specifically for the latest X99 platform and designed to run in Quad Channel mode for maximum bandwidth and performance.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 15-15-15-35
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
ORDER NOW
G.Skill Ripjaws 4 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Red (F4-2400C15Q-32GRR) @ £449.99 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
Only £449.99 inc VAT.
ORDER NOW
G.Skill Ripjaws 4 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Blue (F4-2400C15Q-16GRB) @ £249.95 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
G.Skill Ripjaws 4 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Blue (F4-2400C15Q-32GRB) @ £449.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
OcUK does not really have any competition on DDR4 we don't only have the largest selection in Europe and we shall be adding more brands soon such as GeIL and TeamGroup. We also have the largest IN STOCK selection of DDR4 as well.
We also have all Intel 2011-3 CPU's in stock and we also have the largest range of the new 9xx cards available and again with the largest selection of in stock cards.
LIKE A BOSS!
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.35v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- Voltage: 1.20v
ORDER NOW
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
LIKE A BOSS!
