** OcUK BEST RANGE OF DDR4 IN STOCK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
People seem to be struggling to find DDR4 in stock, so first of all be sure to check our DDR4 section as we've never being completely out of stock of DDR4 once, we've always had something in stock whether it be from Avexir, Crucial, Corsair or G.Skill. :)
OcUK DDR4 MEMORY SECTION - CHECK IT OUT (CLICK HERE)
DDR4 SKU's IN STOCK NOW (24/09/2014
Crucial 16GB (4x4GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K4G4DFS8213) @ £169.99 inc VAT
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that’s exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
Load applications faster and run demanding programs without lag. Crucial DDR4 memory debuts at 2133 MT/s – more than 30% faster than DDR3 memory technology.1 Even better, as DDR4 technology matures, speeds are projected to hit 3200 MT/s – twice what was possible on standard DDR3 memory.
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial DDR4 increases memory bandwidth by over 30%, allowing your system to handle more data at once. As DDR4 technology matures, bandwidths are expected to achieve up to 25.6 GB/s – twice that of standard DDR3. To maximize bandwidth, Crucial DDR4 memory is optimized for nextgen platforms that support four channel memory.
Get better performance – using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 consumes 20% less voltage than standard DDR3 technology. Crucial DDR4 modules also contain other efficiency features, for an overall power reduction of up to 40%.
As a brand of Micron, one of the largest memory manufacturers in the world, Crucial DDR4 memory represents the future of computer performance. From the original DDR technology to DDR4, we’ve engineered the memory technologies that have powered the world’s computers for 35 years and
counting. When you choose Crucial DDR4 memory, you’re choosing memory that’s backed by a limited lifetime warranty2 and designed for the world’s leading systems. Don’t settle for anything less.
Specification:-
- 2133MHz (PC4-17000)
- CAS Timings: 16-16-16
- Voltage: 1.20v
- Warranty: Lifetime
Only £169.99 inc VAT.
ORDER NOW
Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) @ £329.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £329.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit (CMD16GX4M4A2666C16) @ £307.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- 2666MHz (PC4-21300)
- CAS Timings: 16-18-18-35
- Voltage: 1.20v
Only £307.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (CMD16GX4M4A2666C15) @ £349.99 inc VAT
Specification:-
- CAS Timings: 15-17-17-35
- Voltage: 1.20v
Only £349.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 32GB (4x8GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit (CMD32GX4M4A2666C16) @ £599.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £599.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit (CMD16GX4M4B3000C15) @ £499.99 inc VAT
Specification:-
- 3000MHz (PC4-24000)
- Voltage: 1.35v
Only £499.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit - Black (CMK16GX4M4A2666C16) @ £239.99 inc VAT
Vengeance LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom. Each IC is individually screened for performance potential.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There’s XMP 2.0 support for trouble-free automatic overclocking. And, they’re available in multiple colors to match your motherboard, your components, or just your style.
Specification:-
- Voltage: 1.20v
Only £239.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Black (CMK16GX4M4A2666C15) @ £249.95 inc VAT
Specification:-
- Voltage: 1.20v
Only £249.95 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Red (CMK16GX4M4A2666C15R) @ £249.95 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Black (CMK16GX4M4A2800C16) @ £289.99 inc VAT
Specification:-
- 2800MHz (PC4-23000)
- CAS Timings: 16-18-18-36
- Voltage: 1.20v
Only £289.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Blue (CMK16GX4M4A2800C16B) @ £289.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
G.Skill Ripjaws 4 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Red (F4-2400C15Q-16GRR) @ £249.95 inc VAT
G.Skill Ripjaws 4 perform in G.Skill typically fashion, crazy fast! Based on Hynix IC the G.Skill modules come recommended by 8 Pack himself as they have great overclocking ability and the price is always very competitive in market.
Overclockers UK is first with the G.Skill range and Ripjaw 4 is designed specifically for the latest X99 platform and designed to run in Quad Channel mode for maximum bandwidth and performance.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 15-15-15-35
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
ORDER NOW
G.Skill Ripjaws 4 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Red (F4-2400C15Q-32GRR) @ £449.99 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
Only £449.99 inc VAT.
ORDER NOW
G.Skill Ripjaws 4 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Blue (F4-2400C15Q-16GRB) @ £249.95 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
G.Skill Ripjaws 4 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Blue (F4-2400C15Q-32GRB) @ £449.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
OcUK does not really have any competition on DDR4 we don't only have the largest selection in Europe and we shall be adding more brands soon such as GeIL and TeamGroup. We also have the largest IN STOCK selection of DDR4 as well.
We also have all Intel 2011-3 CPU's in stock and we also have the largest range of the new 9xx cards available and again with the largest selection of in stock cards.
LIKE A BOSS! :D
LIKE A BOSS! Love It. :D
What's the cheap stuff like that Crucial are doing for overclocking.
Genuine question, why is DDR4 so dam expensive? Is it harder to make?
RAM is hard and expensive to make and unless you are supplying to a good portion of the market, making a profit at it has to come from high margins rather than high volume. The price will come down as more systems requiring DDR4 enter the market
Yes extremely hard to make, hence limited stock availability.
Its not actually hard to make its just most fabs are making DDR3 some limited DDR2 and flash... Fab runs are being moved over to DDR4 as it will slowly go mass market but at the moment it is a niche product and as such its a niche price.. Technically though there is no huge difficulty in making the stuff, its just a case that the big players will want to balance supply and demand.. Remember there is still a huge DDR3 market out there as well so they wont just switch everything straight over to DDR4 because X99 needs it...
Nope it is very hard to make!
We deal directly with Hynix and the outputs over the last two weeks have being dreadful, their DDR4 production line is having major issues. Otherwise we'd not be experiencing such a drought. :(
Hi there
We are the first in the UK to get stock of Kingston Predator DDR4. :D
Kingston Predator 16GB (4x4GB) DDR4 PC4-19200C12 2400MHz Quad Channel Kit - Black (HX424C12PB2K4/16) @ £259.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- Tested Latency: 12-13-13-35
- Tested Voltage: 1.20-1.35V
- SPD Voltage: 1.2V
Only £259.99 inc VAT.
ORDER NOW
Even better they have vastly improved the performance, it is now CAS12 instead of CAS15!!!!! :eek:
Hi there
We further expand our range of in stock DDR4:-
GeIL EVO Potenza 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Red (GPR416GB2666C15QC) @ £259.99 inc VAT
Potenza, the Italian word for “power”, hence the name of GeIL’s latest top of the line DDR4 Gaming Memory – EVO POTENZA. Speed of up to 3200MHz, available in Quad and Dual-Quad Kits, the DDR4 EVO POTENZA is designed for the latest Intel X99 chipset for maximum performance and compatibility.
EVO POTENZA is equipped with the Potenza heat-spreader, designed with GeIL’s MTCD – Maximum Thermal Conduction & Dissipation technology for superior cooling efficiency. EVO POTENZA is the new DDR4 performance benchmark that powers up your desktop.
Specification:-
- Tested Speed: DDR4-2666 MHz (PC4-21300)
- Tested Latency: 15-15-15-36
- SPD Voltage: 1.2V
ORDER NOW
GeIL EVO Potenza 32GB (4x8GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Red (GPR432GB2666C15QC) @ £449.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
GeIL EVO Potenza 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Red (GPR416GB2800C16QC) @ £289.99 inc VAT
Specification:-
- Tested Speed: DDR4-2800 MHz (PC4-23000)
- Tested Latency: 16-16-16-36
- SPD Voltage: 1.2V
ORDER NOW
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01) @ £199.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- SPD Voltage: 1.2V
Only £199.99 inc VAT.
ORDER NOW
Can anyone beat us?
LIKE A BOSS! :D :D :D :D :D
It gets better, now let see them price come down. :)
I love the way people just dont listen . lol. Not just directed at you but to everyone wanting DDR4
Its a very small market currently and as stated some serious production issues atm.
If demand keep growing for the X99 platform the likelyhood is that DDR4 will increase before decreasing.
If demand is high and supply is low its always been that way
