OCUK Build with thunderbolt 3
18 Oct 2002
Aberdeenshire
Looking for a OCUK built system that supports the Asus thuderbolt x3 card.
Can anyone help?
asrock, Asus, Aorus support TB3 add in cards, was only the older Z170 Gigabyte board that had support without the need for add on cards .
https://www.overclockers.co.uk/b-gr...cket-1151-ddr4-atx-motherboard-bg-506-gi.html
Chipset + Intel® Thunderbolt™ 3 Controller:
- 1 x USB Type-C™ port on the back panel, with USB 3.1 support
- 1 x USB 3.1 port on the back panel
But B-grade and older tech - could get them to build an older 7th gen system around it though - not sure if having it pre-built they'd give full 3 year build warranty to the board as well .
easiest option would be to add in a TB3 card
good B360 boards support add in cards as well , to keep build cost down and use a non k 6 core i5/ i7 depending on your needs
https://www.overclockers.co.uk/giga...cket-1151-ddr4-atx-motherboard-mb-56d-gi.html
https://www.overclockers.co.uk/asus...cket-1151-ddr4-atx-motherboard-mb-6b8-as.html
